aussie7mains
If you think your ring seal is not right, there is a fix. Take it out on the road, get into top gear, accelerate at WOT from about 50km/h to as fast as the road will allow (100 in Australia if outside the metro area) do this about 10 to 20 times, problem should be solved. Ive assuming you have recently bored and honed the block. Dont worry about loading up the bearings, this wont cause any damage. The moly in pistons rings is put there as an anti scuff agent to aid quick run in. Youve said you only have 150miles on th engine, so dont delay, do it now. Ive had to do this on a BMW 2002tii I re ringed many years ago, I left it to idle too long! Go to it.Thanks aussie7mains! That's quite a set-up you have there! We are certain that you are right... we have excessive blow by at the rings. Pretty sure they aren't seated in yet. This engine was built with 10:1 JE forged pistons with chromoly rings. We put a new stock oil pump on, in case the original one was a HV pump. After removing it, we found out it was also a stock pump. We believe we have the problem resolved (see above post). Fingers crossed. Thanks again!
