Goldie
Looking for help from anyone who may have experienced a similar problem. Any of you who have followed our build, know that we have a hi-perf 200 w/ Aussie head, mild performance Clay Smith Cam, Yella Terra Roller Rockers, etc. The car runs like a dream. Tons of power (very similar to a 289). We are running a Classic Inlines finned aluminum non-baffled valve cover (for clearance of the YT Roller Rockers). At first we tried chrome push-in breather elements. Tons of blow-by that soaked the entire engine compartment. Cleaned up that mess and tried another set of breather elements from Speedway Motors. Custom polished aluminum breathers with one being a true PCV valve. They come with closed grommets that we put a small 3/16" hole in the side for inside pressure release. After 5 miles, we had another mess on our hands and smoke pouring out the exhaust because the PCV valve sucked in engine oil. I received a tip from Matt Cox of Vintage Inlines to purchase grommets that have a built in baffle in the rubber and a small sponge like filter at the top. Unfortunately, the inner diameter of those grommets is too small to accommodate any of our breather elements. Also, we are running oil through push rods and have the restrictor in the block that has been recommended for use with oil-thru push rods.
As much as I hate this for any of us, I am hoping that some of you may have experienced this before and might have a resolution to this problem. The way things stand, we can't drive the car. Ugh!!
Appreciate your help, as always.
