smontalvford
May have answered my own question, looks like I need Pertronix 1261 since I have a C shape shaft for my dizzy, got the 1261, I guess I will find out if this was my issue all along…
Hey again. . It sounds like an odd ignition miss, fire cuts out completely then jumps back to full fire. Focusing on the Pertronix is a good starting point.May have answered my own question, looks like I need Pertronix 1261 since I have a C shape shaft for my dizzy, got the 1261, I guess I will find out if this was my issue all along…
Yeah I got the 1261 coming and here Wednesday, fingers crossed that’s it. I’ve been chasing this issue for months and it sounds like finally this could be it.Hey again. . It sounds like an odd ignition miss, fire cuts out completely then jumps back to full fire. Focusing on the Pertronix is a good starting point.
You can verify that it is the spark- especially easy with what seems to be "mass-miss firing" for a full second or so at the time- by hooking a timing light to the coil-to-distributor cap wire (not #1 wire). Start up, and shine the light at any reflective surface. ANY gaps in the light, you have isolated your issue to ignition miss.Yeah I got the 1261 coming and here Wednesday, fingers crossed that’s it. I’ve been chasing this issue for months and it sounds like finally this could be it.
Yes, this is critical.I would double check and make sure everything is gapped correctly!
I’m not trying to pretend that I know what I’m doing here, can you even tell me if I’m remotely on the right track?hoboy, read/understand this:
(from the Tech Archive at top of this page blue horrizontal line just right of center)...Load-O-Matic Distributor & Spark Control Valve
How The Stock Load-O-Matic Distributor Works Here is a little clarification on how the "Load-O-Matic" distributor works, along with the infamous "Spark Control Valve" (or SCV). Not only is it important to know how they work, especially if your...fordsix.com
My manifold has one hole for a vacuum line now and that auto trans vacuum line going there, I assume I can put a T so I can run the line from the distributor as well? Then cap the hole on the carb where the distributor line used to go to?Yes, the dual advance distributors run good on manifold vacuum. That's how mine is set up right now, an 1100 with a SCV and an unused capped off distributor line out, and a dual advance distributor running off manifold vacuum.
yes that will be acceptable.My manifold has one hole for a vacuum line now and that auto trans vacuum line going there, I assume I can put a T so I can run the line from the distributor as well? Then cap the hole on the carb where the distributor line used to go to?
Good to know!Just saw this post.
Had a similar experience back in the mid 1970’s with a 170 having a rough idle. It turned out to be a stretched timing chain.
Compression test was good. I do not have a loadomatic distributor actually. If you read my earlier posts you will see progress here or not, not sure. Latest thing to try is a 3.0 ohms coil, the one I have is 1.5 and it’s wrong for my setup.Did you ever do a compression check? When you do one keep the throttle wide open.
If the compression is ok, get rid of the loadamatic distributor & either get a carb. with no SCV or modify yours so you can get rid of the SCV.
Or get a DS11 distributor with a non-SCV carb.
