Well I wanted to come back to my original post because I FINALLY got around to finishing my build. Life man.... things get in the way
. In the end I used lots and lots .....and lots of your advice. Couple of things I'd echo in case anyone is reading this later on.
A. Go ahead and buy the ford inline six book by Matt Cox and Barton Maurer It's worth having. And makes the build really simple.
B. Watch Richard parmenter *spelling" ,series on YouTube it's very thorough and correct.
C. JUST BUILD IT
I have a tendency to overthink things, and I'll study things to the smallest detail, but you can do it! I'd convinced myself that this motor was something different....if you've never built an internal combustion engine it is something different, but if you have been inside an engine a time or three it's all familiar ground. While this engine does infact have a unique head with it's integral intake log, it's still fairly straightforward and honestly a simple engine.
Literally everything you need to know about these motors is right here in these forums. You will get different perspectives from different people and that's awesome, and VERY helpful. Keep in mind your build doesn't have to be exactly like the other guy, but listen to the other guy, he may have a perspective that can impact what you're doing.
My motor is nothing special, it's certainly not factory, but it is one of, if not the smoothest running motor I've personally ever built. I'm pretty sure I could set a cup of coffee on the valve cover and not spill a drop, and I absolutely wasn't expecting that!
What I did.
Local machine shop milled the head. New valves, guides, springs, modernized the seals with viatron seals. Added a little bigger valve, and did some minor bowl work. I'd have to ask my guy what all he did specifically, but the head was honestly a work of art when he was done with it. This particular machine shop ONLY does engine builds and this particular machinest had built tons of these heads years ago, he said he hadn't done one in sometime, because let's be honest, we are a dying breed.
At home machine work I honed the cylinders myself with a cheap cordless drill, I couldn't tell ya what stone I was using, I used spray lube from dollar general while honing. I had a big ridge in the two outermost cylinders, I cut them with a borrowed parts store ridge cutter. I'm no machinest again everything you need to know to do this is on this forum....and YouTube
All bearings replaced, everything was within factory spec. King brand rod bearings, perfect circle (nos from eBay) main bearings, dura bond cam bearings. DON'T LET YOUTUBE CONVINCE YOU THAT CHANGING CAM BEARINGS IS HARD, with a cheap install tool from eBay and a flashlight to shine through the oil passage I had no problems on this engine or any other engine I've ever done. YOU CAN DO IT.
Melling oil pump, cloyes timing set, Elgin brand lifters from Amazon or eBay. A chrome valve cover from eBay, a dual outlet header from eBay, a HEI ignition from eBay, a carburetor "Holley" 1904 style again from eBay. Only thing I didn't replace was the factory cam, it was mint, and honestly I just didn't see the point of dropping coin on a cam. And all new gaskets felpro brand. And I bought a bolt kit online from some random company that had them. It was good to have all the bolts I'd lost and previous owners had replaced with random bolts. I cleaned the adjustable rocker and my push rods up with some diesel and a wire brush, because I use diesel to clean all things covered in oil and grime, lubed everything up as I was building, set the lash and called it good. I've ran it enough now that I've adjusted the valves once, it's super easy and honestly I'll likely do it periodically just as routine maintenance.
I wire brushed the block, washed it, replaced the freeze plugs (I always use a little "elephant snot" yellow weather stripping adhesive on mine) primed it with off the shelf red primer, brushed on two...or four coats of Rust-Oleum navy sail blue and called it good. I painted the timing cover and oil pan silver, because I had some base coat silver, and I cleared it with top coat clear....yes I cut and buffed my oil pan
but I paint cars so I mean....
My point in all of this is to say THANKS GUYS to
everyone that offered advice and guidance, and to tell anyone that might be reading this later YOU CAN DO IT. Rather your doing a factory original numbers matching build or a eBay discount on the cheap build like I did YOU CAN DO IT!
