I've finnaly ordered a bunch of stuff for my turbo s6 project...
Brand new holley 350 circle track (it was cheaper then a standard 350) 2 bll with no choke
It said that it comes with floats for cornering I guess then it comes with the nitrophyl floats
if not I've ordered another nitrophyl float that was before I even bought the carb
holley adjust a jets <--- any comments on these in turboch. carb good bad? already bought it
mallory 4309 fuel pressure reg. (boost referenced)
Carter In-Line MFI Fuel Pump p5000
bov similar to linc's200
TurboXS Boost Controller
summit getting richer an Im getting poorer....
also bought from a friend a used turbonetics deltagate wg
I got it today my schneider 264 cam with matching springs and lifters! 224@0.050 0.490 lift
good or too big?
I could also get a 244 which is a little above the stock cam.
I also got stainless steel oversize valves from sivalves
but these will not be used for now...
head will be stock one with mild porting (it's good to have spare engines 8) )
2 days ago I wanted to get a mercedes benz kompressor intercooler on ebay the bid started at 26$ and ended at $100 which was too much imo for a used one...
so now I am going to use a small one from a nissan silvia got it for $15
they say these are good up to 12 psi ...I was thinking if converting this to a watercooled one since its small....water going to a pump to oil cooler the return to ic....some people have done this with succes...so they say
but then again need to find someone who can weld alum. for cheap...
the most important thing missing is the turbo itself.. I am going to get 1 from a 300zx which is a t3 for temp. use... when and if I can get this running good then I will get a matched size turbo...
need fuel pressure gauge, boost gauge
next on my list is a zeitronix wideband hopefully in 2 months have saved enough to get it with the boost and egt sensor
I wanted to get a csu carb bonnet but at $165 when it comes here would be plus a $100 import tax :roll:
so I decided that I am going to let my friends at a metal shop make 1 for me
so I got a question about a bonnet design
what about making one that it blows directly into the carb intake and not onto the unused area?
here is a pic of what I am trying to explain....
so as you see I have almost everything needed... 8)
any comments ...suggestions are welcome
good or too big?
