james singleton
Here is what I have currently on my 66'- 200cid engine: a Motorcraft 1940 single barrel carb w/SCV, a Load-A-Matic distributor, and a Petronix elect. ignition! Here is what I would like to do: I would like to install a back-up carb that I have which is also a Motorcraft 1940 single barrel but is a "NON" SCV type carb. I am thinking about buying a 69', or later, stock distributor and installing the Petronix elect. ign. in this new distributor! Do you see any problems with this set-up??? Also; when do you need the dual vac cannister instead of the single vac cannister like I have now??? I know that many people seem to go the DuraSpark dizzy, or other dizzy route, but since I recently installed the Petronix set-up and the fact that I have this "non" SCV carb, I thought I could have two different set-ups! One set would be the orginal Load-A-Matic dizzy with the SCV carb, and the back-up set-up would be a "non" SCV carb with a latter dizzy that is a 69' or newer! This way I would be able to use the Petronix elect ign. system in either set-up??? Make any sense??? Thanks, Jim
