Bubba, Great Info!
Was the 223 head intake flow numbers through the Single or Siamese intake ports?
I spent a lot of time working with the Buick S8 which has 4 Siamese intake ports.
The Siamese ports do not provide equal cylinder fill to the adjacent cylinders because of the intake cycle timing.
When the Salt Flats crew tried to turbocharge, they would lose the cylinders that were lean.
I worked with another S8 project trying to get port injection to work to no avail.
The solution was to convert the head to an 8 single intake port design.
It looks like the most successful Chevy six turbo engines use the Wayne 12 port head for the same reason.
The Montana Salt Flat crew did what they called "Budweiser Engineering" and installed intake tubes directly to the intake valves.
They were able to set several speed records with the Buick S8 engine afterward.
The Ford 223/262 head has both Siamese and Single intake ports which would result in 3 different VEs for the six cylinders.
It also has head bolt interference that was solved above by lowering the bolt seat.
Thoughts?
