Crustang to Mustang
For a first time engine builder which is easier and more cost efficient?
What is your total budget for this car? It would help folks making suggestions if they knew that figure.Which one do you suggest?
A supercharged engine making enough power to lift the front end of your car is in the $10K range.So, I was only going to spend at most $1,000 on the engine. But preferably less than that.
NoSo could I even turbocharge for $1,000?
What do you expect to gain with roller rocker arms?Okay, I guess I'll put my money in rollers and solid lifters...
I've heard that they can work wonders. And can save on your valve stems.What do you expect to gain with roller rocker arms?
What do you mean by "Work Wonders"I've heard that they can work wonders. And can save on your valve stems.
If swapping to a 300 or 4.9 just note that they are about 3" longer than the 200 or 250, so look at what you'll have to do to accommodate.And I'd like to keep an inline just because they're unique. I f I swap it'll be for a 300.
By "work wonders" I mean increase HP. I have not priced the roller rocker arms yet.What do you mean by "Work Wonders"
Have you priced a set of roller rocker arms and lifters and pushrods?
