For the second time I've had a rocker seize on the shaft. I've got a 1965 200 cubic inch block with a 1980 granada 250 cubic inch head. Stock bottom end, and a early model 144- 170 cubic inch adjustable valve train. The head has been modified to accept a 350 CFM Holley carburetor. This is a street driven combination that is used for car shows. Has anyone else experienced this situation. It first happened on #1 Cylinder, second rocker, causing a backfire that blew the plug out of the front end of the intake log, and bent that pushrod. Disassembled, cleaned, filed, honed a reassembled. It ran for about a year, and unfortunately happened again a few days ago. This time it was a different rocker, #4 push rod once again off the rocker, but not bent. Had to use a puller combination to disassemble the rocker. I run a quart of Lucas additive and 15 w 50 Mobil one oil ( the same combination I run in my 1956 Ford pickup with a 455 Olds engine ). Any one else experiencing this situation.
