What you describe is exactly how I remember the first PCV systems being implemented. A rubber grommet with a PCV valve in the former draft tube hole along with a vented oil filler cap. You won't feel a lot of vacuum at the cap. We used to have a tester which you placed over the oil fill opening and the draft from the PCV system would pull a small ball around a scale to indicate the amount of flow.I found a rubber grommet that fit into the factory draft tube. The lower half of this tube was missing. Put the pcv in this grommet. It's from some kind of GM V6 which has a small hole in it, (fixed orifice) Ran a copper tube to a vacuum port for the wipers below the carb. I'm going with electric wipers. The oil fill cap has a white pcv type of filter mesh that I oiled to filter out dust. Only run in the shop. does have a slight vacuum at the oil fill tube. Idle mixture screw only changed about 1/8 turn richer. should work just fine.
Joe
Joe- I've been following this thread. I've got 2 flat-head Ramblers with the vent tube. . the only concern that comes to mind, if I'm picturing your install correctly, is if the PCV valve is facing down, with the vent-tube above and the manifold hose below the valve. There will need to be some sort of liquid oil drain-off somewhere before the valve. If not, over time the valve may pull liquid oil into the intake intermittently.Should work. But the engine is out now and cab is off for frame clean up and paint. Hopefully on the road this summer.
Joe
The valve side cover has a oil separator mesh just before the road draft tube. Should keep doing its job. There isn't a high enough volume of air flow to pull any extra oil into this tube. Any oil that would collect will be drawn through and shouldn't be a problem. You could run a hose and mount the valve up higher, but that is when oil would collect in the bottom of the hose.
Joe
Most automotive engines pull fresh air in one end, and vapors out from the other end of the valve cover, on top of the engine in OHV. All vapors have to come to the very top of the engine to be removed. Dealing with a flathead, the only options are the valve cover, which is well down on the side of the engine, where the draft tube is now, or the pipe where the oil is added (which is also the dipstick), which ends in the crankcase.I think if that is the only way to draw air it would help but I always heard it's better to have the valve cover be in inlet side of the system and the crank case be the out. Keep all the fumes away from the upper engine components.
I could be wrong here tho.
This is not as favorable an option by physics. The natural heat of the vapor causes it to rise, so fresh cooler air into the crankcase, PCV to manifold from the current draft tube where the vapor is naturally migrating is better IMO. Plus the fill tube has the mesh screen already, which is sufficient for fresh air intake unless in a high-dust environment.You could install a pcv in the oil fill tube. The oil fill cap would need to seal tight. You would need to put some type of filter on or in the road draft tube . This would be another alternative to what I did.
