Okay hardcores, here's the deal:
I've been studying up on header and exhaust design, and having had more than 25 years of occasional successes taking David Vizard's advice I tend to lean towards what he says. Going by Vizards calculations in his latest book, and the dimensions of my Clifford dual out header (which only has primaries) I get the following:
(Vizard suggests a multiplier of 1.68 from primaries to secondaries for a street engine)
* Primaries are 1.5" diameter and average out to 21" in length measured from the exhaust valve.
* That means my secondaries ought to be 1.5 x 1.68 = 2.5", and about the same length as the primaries.
* That means my exhaust should be 2.5 x 1.68 = 4" (!!!) and about 36" long, dumping into a roughly 300 ci termination box (and then out to whatever will flow adequately)
Well, those are the numbers according to his latest book, although it focuses on 4:1 headers so the extra step (tri-Y) is probably throwing me off. My gut tells me 4" is insanely huge for a 6000 max rpm motor, so THIS is my actual plan:
*Secondaries at 2.25" and 21" long
*y-adapter 2.25 to 2.5" for 36" into the termination box.
The question is, should the 36" length really be 3" instead of 2.5"? I know 3" seems really big, but plenty of 302 V-8 run that size and bigger with only 152ci per bank, so... Nevertheless, I think I'll err on the side of small and make my pipe 2.5" into a single-in/dual-out box (Flowmaster or Jones most likely) and then 2" dual out to the back through some Porter mufflers.
As a point of comparison, my current exhaust dumps the header outs into a 2" to 2" y adapter with only 8" of length and then steps up to a 2.25" exhaust about 45" long to a turbo muffler. Pretty ugly. I wonder why my new awesome engine didn't make the power I expected. So, I'm going to hand make this intermediate section and have it ceramic coated to match my header. Should be pretty sweet and certainly a better match for my high-revving engine.
