Hey there fellas, I am nearly at the end of my XW rebuild and at the moment I am happy with my current setup (this block in it's present condition (well with a standard cam and original morse taper timing setup) and a standard head and carb in an XW ute was an absolute FREAK. it would happily rev to over 7G and in the wet with a 3.23:1 diff would get no traction in any gear (single rail) for about 300 metres if you tromped it...hell, in the dry you could happily start a burnout in 3RD). But at some point I'd like to get electronic ignition for the old girl on the recommendations of others. At the present time my driveline consists of a pre X-Flow 250 block (I think it was originally in a corty cause where the dipstick goes in at the rear in a corty is filled by a bolt in this block and it has the dipstick in the standard position now)), 10 thou under big ends, 20 thou over XF unleaded pistons, Crow #2666 cam, double row timing, , new oil pump, lifters....everything. 2V head, 34 ADM?? Weber from an XE with custom hand made (I mean hand made... nothing but a drill and hand files) alloy two-piece adapter block, Ramflo filter, Hand made accelerator linkages. T5 manual from an XF, 2.92:1 disc LSD from ZJ fairlane and EA fairmont GHIA buckets.... oooh the luxury of adjustable lumbar support LOL ...so much better than the standard benchy. Anyway, I have been told by a few people that I can hook up an XF dizzy to my machine and give it that much more potential, I just have to add a spacer to the bottom of the dizzy as they have a smaller diameter than the old ones. Does anyone know if this is true and are there any other issues. (a mate of mine put his XF engine into his TE corty and ended up putting an XE dizzy in to eliminate the need for the computer for it) Would an XD/E electronic setup be the go for me? Cheers, Tony
