KASTANG asked
Can nitrous be discussed in this forum also?
Sure, why not. It's just chemical supercharging!
The reason why nitrous is a bit of a worry on a poorly distributed air/fuel mix is the excess fuel factor. If there isn't the correct cc/minute flow of gasoline to suppress the lean-out condition nitrous oxide creates, then the other or even number 5 and 2 cylinders may roast the ring lands. The great thing is that the I6 has very strong rods and crank...there isn't a lot of bending moment on anything, even with a poor rod ratio. The effectiv compression is good, and the engine is well cooled at number 1. The real issue is number 2 and 5, the cylinders most likley to die from detonation. On the log or cross-flow, these are the ones that get hammer time.
The 2v head breaths very evenly, and I'd be looking at ensuring the large 42 mm ports are feed with sufficient excess fuel via a port gasoline/n20 system. Then read spark plugs, and experiement. With good quality US pistons from the I4 HSC engines, this would be perfect. I'd say you could go up quite a good deal more than the 50% of stock hp rise. You may get into the 275 hp level's if you have only 130 hp. The cam has to be right for nitrous, with good duration on the exhast to bleed off the exhast.
One other thing is differential compression ratios 0.5:1 lower on 2 and 5. Not silly if you want to avoid detonation.
On another tact, just a stock D7 log with a port gasoline/n20 system would be okay only if feed with a good mixture distribution from a dual carb set-up. The stock 1.75" hole does look a bit of a worry, when there is up to one quart of gas per minute traying to feed two branches with a concentration time of 5 milliseconds for each side. Thats wayyyyy too long for an engine which fires a cylinder every 290 milliseconds at 5000 rpm. If there is not enough fuel in the cylinder, it'll never safely get the percentage increase in power.
Another way to put it, is every second, a 275 hp I6 engine needs almost one tea-spoon of gas in each cylinder, each second. If it doesn't get that while the carb barells and nitrous is being delievered,guess what, it'll lean out on the outer cylinders! That 'time of concentration' thing again.
But, hey, the 200 has a huge factor of safety! It'll just
a) blow number 2, 5 or 6 on the fire ring of the gasket
b) melt the spark-plug head
or
c) break a ring land if it gets too much termal loading in the chamber.
Remember, its possible for a 155 hp unleaded 350 to hit 500 hp on Nitrous if its done right...on a stock engine with manifold bolt-ons and th right cam. 275 hp on a 100 net hp log I6 shouldn't be a problem!
Hmmm, wonder what a 300 would do? Kill Chevies?????
