Sounds like Larry Widmer and Bruce Crower and the Miller Bros learned from engines the most important lesson..non direct injected gasoline engines are detonation limited.
See Widmers Soft Head/ RollerWave engines, either supercharged or non supercharged.
http://www.hotrod.com/featuredvehicles/ ... _civic_si/
The soft head gospel is a lot like Crower and Millers, and its all about reverse engineering from a maximum detonation point. The cam became the whole reverse engineering inflection point. Australian Sam Blumstien said it best...there are no wrong cam selections, only wrong engine combinations. Because canted valve engines like the 335 and 385 Fords are great power producers, but poor detonation survivers, that's the kind of engine Widmer majored in. A super charger 50% of the engine size, an 11:1 or 14:1 to 16:1 non s/c compression ratio, and aspirations ratios down to 3300 on a normally aspirated V8...6% more specific power than a NASCAR V8, with 20% less cam duration.
See
http://mpgresearch.com/discussion/1985- ... -soft-head
Anyway, the combo's were emission compliant, but the piston design was very specific, a lot like Fords direct injection stratified charge ProCo" (programmed combustion)engines, and as a custom engine, likely to be a sucess, but as a production engine, a bit of a commerical risk.
