Jamie Miles
My '72 Ford Maverick is (and has been for the past 7 years/171,000 miles) my daily driver. Current stats are internally bone stock 1980 200 from a Mercury Capri, SROD 4 speed O/D transmission, 2.79 gear. MSD-6 ignition/blaster II TFI coil, Duraspark II distributor, single out header that then Y's into dual exhaust, Delco 12-SI 90 amp alternator and an early 60's GM Rochester BC 167 cfm carb. Oh, and a Taurus electric fan on the radiator that's only on if the engine gets over 200 degrees.
I'm currently getting about 23 mpg in town (shifting at 1800 rpm, never exceeding 60 mph) and anywhere from 27-30 mpg hwy. depending on speed. Overall, the car runs and drives excellent and I'm very happy with this setup. It's not 'fast', and I don't need it to be. It runs along with traffic just fine.
Problem is, the carb, now being around 50 years old, has developed a problem where the throttle shaft is worn out and wobbly. Basically it's just worn out and I'd need to replace the bottom 3rd of the carb to fix it, which I haven't ruled out. But before I get into looking for a parts carb to fix mine, is there any other type of carb I should consider that may get even better gas mileage? I've had a Carter RBS and YF on the car before and wasn't really happy with them (never could get the YF to run right). Was thinking about trying something like a Holley 1904?
