Turbocharger?
Fuel injection system?
Fuel injection stuff is next on the list! Tracking down a lower efi intake, then figuring what I'd like to do on the upper intake/throttle body
Turbocharger?
What paint did you use?
Thanks!Looks Great!
What do you have for crankshaft end play?
Also what did you use for valve springs?
The endplay is measured by placing a dial indicator on the end of the crankshaft, then you pry the crank in one direction, zero the dial and pry the other direction to get the endplay reading.Endplay looks to be right at 0.007". I couldn't really get any movement by prying, and that was measured at the back of the #5 bearing
You will need a dial indicator with magnetic base to install and degree the camshaftUnfortunately I don't have a dial indicator setup right now. Best I could do is with feeler gauges.
