then you would want a roots-type blower, most likely. (someone had laid out a plan to get 6psi by 1krpm and 10 psi by 1500, but i dont' remember how) Any 300 after about 1987 is multi-port injected, and there are aftermarket 'universal' injection kits available. Bad thing (if you consider it bad) about the "4.9" is that it's a dual batch-fire system. the injectors are divided into two banks of three injectors: three front injectors open at the same time, and the three rear injectors open at the same time. The odd part is that all three injectors of each bank open three times per cylinder cycle. or all three injectors fire 1/3 the necessary fuel for their individual cylinder any time any cylinder of that bank opens it's intake valve. Kind of a wierd set-up, and quite the horrible explanation of it.
Roots blower, yeah. that or a Kenne-Bell Whipplecharger. Turbo, if it's sized properly, but definately not a centrifugal supercharger for this application.
Ern
