I was just surprised that the chamber volume was as low as 74cc but that's OKJust talked to Dan the machinist.
he said it was .01 or very little on the flat.
To do precision timing correctly with any sequential system you should use a 60-2 tooth trigger wheel on the crankshaft and modify the distributor for a single cam sync pulse for sequential timing of both the injectors and the six ignition coils.This is something I’ve been thinking about but haven’t brought up. I am open to all options. I really like the idea of doing a non-distributor type ignition and using some sort of trigger. I used a Holley sniper setup(fuel and spark) on my old 69 and really liked the product. The Holley EFI looks really nice but I have not looked at it in depth. I’m not completely against a distributor either. I really want the best quality and reliability. Help me
The 300 cams have a threaded hole in the cam snout that you could use to bolt an extension to that would pull up against the cam gear.On a 300, I'm thinking that a milled slot in the cam gear, 180 degrees, would suffice as the 1x wheel. I need to see how much room there is,
YesI take it we are talking cam and crank sensors?
