Actually, the stroke does affect the harmonics a great deal because the journal overlap in the crank changes with the stroke. The shorter stroke cranks are often more desirable because they are usually lighter, but also more rigid because they have more journal overlap and resist harmonics are specific frequencies more than longer stroke cranks with less journal overlap. Also, an ultralight rotating assembly(lightened and knife-edged crank, aluminum rods and hollow domed pistons) can move the harmonic frequencies higher up in the RPM because there is less mass pushing back on the throws to flex it. Our 292 Comp Eliminator cranks were lightened by almost 12 lbs and the harmonic frequency that originally was around 6200 RPM moved to over 7000 RPM. So it can be a benefit to trim weight off of the crank where you can.
