In Australia through the use of a shorter ACL piston one is able to fit longer 200ci conrods in a 250. For those who dont know, this is done to correct was is considered to be a poor rod to stroke ratio in a 250ci.
Although the the rod to stroke ratio is a point of contention amoung many who know this subject better than myself. I have spent endless hours trying to find if there is any common oppinion on the subject.
There is an awful amount of conjecture and where real extremes are involved there is no doupt the the Rod to Stroke ratio does have a big effect. So Ill try and keep what is said as it relates to a ford 250.
It appears that almost all agree on one thing that a poor ratio does effect the wear of an engine. This is something that can be measured and a poor ratio is harder on the pistons due to the fact that it tends to drive the piston into the sidewall. (mind you some of the high reving Hondas have about the same ratio as a 250 and are known for durability as is a Ford 250)
the effect on HP is a bit less certain but it seem if it does have some effect its only very small. An article called "Great Myths I have Known and Loved" says that an article in 2001 National dragster magazine conducted test altering the Rod ratio on a 500 inch Chevy Pro Stock engine and Dyno tested the results apparently long rod short rod it didnt seem to matter he says that there was not much if any HP differences recordered. Other tests can bare this out.
Wear, HP, what about revability and the effect of any additional strain the rod ratio might have on and engines bottom end. There is a good article called Rod ratio Kinematics although not done on a Dyno its computer program findings show clearly the effect of an increase of a rod of about 1cm in an S 14 engine with an Evo 111 crank. this is about the same increase of fitting an aussie 200 rod into a 250.
The results are that there was an increase in the engines red line. But guess by how much, wait for it. 123 rpm thats right a staggering, mind boggling 123 rpm. And at what revs I hear you ask only about 8323 rpm up from a previous 8200 rpm with a 1.5 % decrease in piston acceleration. In the article it says that this should not be considered inconsequentual. Well maybe not for a dragster on the strip wanting to blast to the moon, but for me and my 250 2V its inconsequentual.
At a rough guess it would amount to maybe about a 60 rpm increase on my 250 2V 4600 redline. Wow I can hardly wait to get those 200 rods in there. mind you Ill have to get a much more accurate Tacho, its kinda hard to pick a half a hundred rpm increments on my tacho. The wear factor must also be dirrectly linked to revability.
Perhaps the argument in all of the rod ratio debate should not, "if it makes a difference" but "how much of a difference is it going it make". But For me the 200ci rods I got for this will be staying on the wall in the garage for a very very long time. Oh by the way the effect of a so called poor ratio is improved by a longer stroke. A good example a this is a 250 Ford. Oh and just one other thing, my mate accidentally reved his 250 2V to 7000 rpm the other day (and yes, it still runs)
