65coupei6 Famous Member Staff member VIP Jan 11, 2022 #1 Just doing some research. I have read you should switch to a colder plug when adding a turbo, nitrous or a supercharger. Also closing the gap because as the boost increases, smaller plug gaps are required to prevent spark blow-out. True?
P pmuller9 5K+ VIP Supporter 2018 Supporter 2021 Jan 11, 2022 #2 65coupei6 said: Just doing some research. I have read you should switch to a colder plug when adding a turbo, nitrous or a supercharger. Also closing the gap because as the boost increases, smaller plug gaps are required to prevent spark blow-out. True? Click to expand... True. As cylinder pressure increases the resistance between the plug gap increases. Last edited: Jan 11, 2022
65coupei6 Famous Member Staff member VIP Jan 12, 2022 #3 Ok. Thanks. I am just getting prepared for an upcoming project.
P pmuller9 5K+ VIP Supporter 2018 Supporter 2021 Jan 12, 2022 #4 The smallest gap we ran was .025” with 35 lbs boosted methanol. What type of project are you looking at?
65coupei6 Famous Member Staff member VIP Jan 12, 2022 #5 Supercharger. Looking at 6-8 of boost. Running with a FiTech. I was thinking .035 gap?
P pmuller9 5K+ VIP Supporter 2018 Supporter 2021 Jan 12, 2022 #8 .035" plug gap should be good. You probably already know this, use 40 to 50 ohm/ft spiral core wires.
