yes the number on the block shows that the engine was changed to a 1968 engine with a 1969 head which complicates matters. There was an autolite 1101 (which no longer works) with a large opening and the distributor pictured. I can't find an 1101 to buy so I put an 1100 that I had in stock. I also have a load-o-matic dispenser in stock that I was planning to place.I will take a picture of the Carburetor
Hi Hermitte, this is actually a very good combination of parts I.E. the 1968 short block and the 1969 Head along with your 1968 ? 1969 point Distribitor.
On the photos n1/2 the distributor and the carburettor installed. On the photo n3 the carburettor which I think is the original one of the engine. And on the n4 the distributor which I have in stock. Which combination is best for my engine?
Yes this older Autolite 1100 carb is a major problem since it's not going to play nice with the later model distributor.
The Best Combo for your engine is to either keep using the 1968 / 69 Distributor which is still a decent working point unit or if you wanted to up grade it some you could also use a Pertronix electronic Kit and then add their Flame-Thrower Coil for a hot'er spark at a reasonable cost. You could also go with a newer DuraSpark II Electronic Distributor for a very good improvement also on a lower budget this has been a big favorite of mine that I have done for many years on my own and customer car's and truck's, there are also quite a few other ignition choices too.
For the Carb the 1968 or 69 Autolite 1101 is a very good Carb for your combo of parts if you could find a good one or rebuild the one you have. After this many years the Throttle shaft on the Linkage side can be worn out causing a bad Vacuum Leak there are Bushing Kits to repair the Carb body back to good working condition.
There a couple of other late model 1V Carbs that are a bolt on to your large Log Head, the later Model Carter YFA or RBS that Ford used on the 1970's 200's and 250 Six's you have to watch on the Throttle linkage Arm Pivot Position though as some will use a Push type Linkage and some use a Cable Linkage to pull them. Both types can work very well if you don't mind changing over to the right Linkage as needed. Lastly there are some 2V Carb upgrades so depending on your goals for your Mustang that can also work too.
Here is what you can do right now disconnect the Distributors Vacuum Advance at the Carb and plug that off. Now get a fitting or fittings so that you can hook up the Distributor's Vacuum Advance straight into the Manifold Vacuum of the Log Head usually they will have a Tapped Boss and some fittings or a Plug capping it off that you can use for your Distributors Vacuum Advance Source. If you need help on this and want to post a picture of the 1969 Large Log Head I can point it out better.
Here is the Stock Basic Tune Up Info for the 200 six Engine Combo you have, its done in this order.
Engine should have good Compression in all cylinders if in doubt do a Compression Test. The Fuel Pumps PSI is 4 1/2.
1. Spark Plugs are Gaped to .034
2. Set the Point Gap to 0.027 if you have a way to set the Dwell to 38 Degrees this is an even better setting.
3. Now you can set the Base Timing to 6 Degrees BTDC for a manual Trans Car or 12 Degree BTDC for an Automatic Trans
4. With the engine warmed up good set the Carb to its Lean Best Idle. To do this turn the mixture screw out until you have found the highest Idle RPM. Now turn the Idle Mixture Screw back in 1/4 Turn to lean it.
5. Next set The Curb Idle RPM to 650 RPM for a Manual Trans and 550 RPM for an Auto Trans with it in Drive and the Parking Brake set and the wheels chocked or better yet have a friend put their foot on the brake for you.
Best of luck
