I spent a few hours at the pattern makers on Saturday afternoon. What we decided to do, is to make the first intake universal. So were going to make the intake with a square flange the same size as a Holley square bore carb. Then we will produce adaptors for the different carb options, Holley 2V, Holley 4V, Edlebrock 4V, downdraft Webber, twin side draft Webbers, various throttle bodies, and so on. The adaptors will also allow the carb to be turned 90* so you can install it parallel or perpendicular to the crank.
By doing this, we can use the same intake for numerous applications, which will reduce the overall cost. It also makes it much cheaper to change induction systems later on. All you'll need to do to upgrade from a 2V, to a 4V, or to EFI, is swap adaptors. Were even going to try to design and produce an adaptor for the M90 S/C.
As for the triple intake, we going to try to use the same approach. Will produce the intake so it accepts sidedraft Webers. However, it will also accept a plenum chamber which utalizes a single throttle body (front or rear). Or you could mount triple TBI's, with or without the plenum chamber, thus allowing it to be N/A or boosted. All we need to do, is produce an adaptor to change the bolt patterns. Piece of cake.
On a side note, I also talked to them about producing a new bellhousing for a T5 application. I'm also working on a new heavy duty flex plate for the C4's.
