brian f100
Hi all, I have a 64 F100 with a 223. Does anyone know where i can get info on how to replace the rear main seal? Anyone know the procedure and part #s Thanks!
Thank you so much! the motor is out and on an engine stand. when i turn it up side down, take off the oil pan. would it be easier to pull the crank shaft, or will that tool make it to where i can take out the old and put in the new? again THANKS!The original was a "rope" style seal which had a tendency to leak as I'm sure you're aware. FEL-PRO BS61413 is a two piece rubber seal set that looks like it's designed to replace the original equipment. It comes with instructions and, looks like, some tools to help you along.
Ideally you should remove the engine, turn it upside down and remove the crankshaft but that's not the most practical procedure if you just want to change the seal in a running truck. Basically the process (engine in truck) is remove the oil pan, loosen all main cap bolts, remove the rear main cap, and work the seal around the crankshaft. Work the old seal out, then the new seal in. It is not easy or foolproof and you must be careful not to damage the crankshaft. I think the last time I did one, I went to the hobby store and bought an assortment of brass stock to use as tools for driving the seal around. A look around for a video on the subject might net you more useful information than my brief description.
Lou Manglass
thanks!!X2 Here is the same seal Part number i looked up for that newer type neoprene seal.
1952-1964 Ford And Mercury Rear Main Rubber Seal Set, 223
Fits 223 6-Cylinder The rear main seal is located directly behind the rearmost main bearing journal of the crankshaft. Its job is to keep the oil that sloshes around in the crankcase and oil pan from escaping out the back of the engine. Symptoms of failure are usually a wet area on the rear of...www.ecklers.com
you don’t need to pull the crankshaft just to install the rear main seal. Remove the rear cap and with the engine on a stand you can either loose up all the other main caps or remove them: you want to be able to lift the rear of the crankshaft up just a little so the old seal can be removed and the new seal can side back in again. Clean the seal grove good and side in the new seal. Good luck
Did you ID the seal type you have the old Rope or the newer Neoprene one? You do not need to remove the crankshaft to replace the bottom seal unless you want to. Yes the old Rope type seals can sometimes be driven out or you can use a sheet metal screw to turn into them and then use some pliers to pull them out. the Neoprene seals can be driven out.Thanks!!! i flipped the motor up side down, i removed the oil pan, removed the bottom half seal unit. i see the round seal that goes around the crankshaft, and visually it looks fine. there are 2 straight seals on each side of the main seal unit . 1 is broken and missing about half the seal. to replace the side seals on the bottom half, i think i need to take out the crankshaft. I think? any thoughts? THANKS! i am also thinking of bring a sissy and just replace the bottom half, side seal and putting it back together and pray! CHECK THAT! i re looked and the bottom module has the round half seal that goes around the crankshaft and 1 straight seals on each side. the top is the block, no side seals needed. just the other half seal. now i need to figure out how to remove and replace that top half seal without removing the crankshaft. some on youtube say to tap the old one out and the tap the new one in. any input?
thanks! im waiting for the seals to get delivered. i will keep you all posted.As bubba22349 said, with the engine out, upside down, and bearing caps off you should be able to just about slide the old seal out and rotate the new one in. If you still have the rope seal, it might require a little tugging with a pair of pliers. As long as the crankshaft is clear of the seal it should go smoothly. Whatever you do, just be careful not to nick up the bearings or the crankshaft itself.
Lou Manglass
