Sickboy49
I am creating this post as a case study on setting up a Weber 38/38 DGS (Manual Choke) carburetor with two different distributors. I hope this helps anyone going down the same path that I am. I also have a question or two at the bottom of this.
Distributors:
Stock Load-O-Matic (Vacuum Advance only)
Mallory Dual Point ZC313A (Vacuum/Centrifugal)
Engine:
Rebuilt 1961 223 with stock valves and cam
Bored .040 over
Intake/Exhaust
Clifford Engineering Intake for either a single two barrel/four barrel carb
Exhaust is a custom built header setup derived from a Clifford Engineering truck header
Weber 38/38 (Initial Jetting and settings)
Idles Jets: 55
Idle Mixture Screws: 1.75 turns out
Idle Speed Screw: 1.25 turns in
*Carb Note* I did a lot of reading on the setup of Weber carburetors. The on thing I can definitely say is that the 38/38 does pull vacuum at idle, which contradicts the documentation that I read. Vacuum line to the distributor is coming from the port closest to the choke.
*Note* The Weber Intake/Exhaust and Carb were bought used. I actually bought the whole motor which was from a 1963 truck. It was supposedly rebuilt but by the looks of it, it was leaking oil from everywhere. Also by looking at the plugs it was running very rich. I also purchased a Weber re-jetting kit just in case and I am glad I did. Also I realize this whole process is probably simpler with an electronic ignition conversion but I am trying my best to keep all electronics out of this car.
Case 1: Load-O-Matic
Most documentation says this setup (Weber/Load-o-matic) will not work. After changing Idle jetting the carb was still gasping when matting the throttle. I know this is due to the load-o-matic going to fully advanced at startup. I tinkered with heavier springs but could only get the timing down to 28 degrees advanced at idle. I also found that someone had try to re-jet the air correctors and main jets incorrectly. It was also determined that the idle speed screw only exposed the main idle circuit at 1.25 turns. All Weber documentation says it should be 1/2 turn after contact with the plate. Below is the best setup I could attain, but starts hard with such advanced timing:
Idle Jets: 55
Air correctors: 180
Main Jets: 155
Mixture(s): 2 turns out
Idle Speed: 1.25 turns in
Case 2: Mallory Dual Point
After discovering that I installed the distributor 180 degrees off (thank you guys for the help!) with the vacuum line disconnected the motor fired right up and was the smoothest it has ever been. At idle it was sitting at 14 degrees advanced. After plugging in the vacuum line, it behaved just like the load-o-matic going to full advance (30 degrees +). After tinkering with the carb settings and timing a little I got it down to 24 degrees at idle, but it still starts hard and runs rough at idle. However when you mat the gas she pulls for the moon.
Idle Jets: 60
Air correctors: 180
Main Jets: 160
Question/Observations:
I am thinking about disconnecting the vacuum line to the Mallory as all that the vacuum does remove the breaking affect of a plunger resting against the advance plate. I want to see how much advance at 2500 rpm I get without the vacuum. It is either that or heavier springs on the centrifugal advance arms. Any thoughts?
Distributors:
Engine:
Bored .040 over
Intake/Exhaust
Idles Jets: 55
Idle Jets: 55
Air correctors: 180
Main Jets: 155
Idle Jets: 60
Air correctors: 180
Main Jets: 160
