hi
Head: c9de 6090 m
Block: c6de 6015 b (2x) (currently in the car and a spare) c8de 6015b (spare, locked up)
Carb: motorcraft 2150
trans: 5 speed manual (not a tremec)
first a quick introduction: I'm Henk and I live in the Netherlands. A few years back i bought a 1968 mustang hardtop with a 200 automatic , now that I'm almost done restoring the car I want to go in and rebuild the engine. Along the way I bought another mustang (rustang) almost identical to the one I had, only difference was It had a manual, so it opened up the way to get a 5 speed installed.
First I only wanted to rebuild the 200, but i've been looking around here and decided it would be a good idea to do some modifications along the way (my wallet doensn't think so ). That turned into getting a 5 speed to bolt behind it, which turned into fully hopping up, without buying a OZ head. The plan is to get the most out of the engine as possible with the head i got. It will be a cruise car, so I wont make a lot of miles with it.
The head on the car was just a original small log, but if I understood correctly a 250 large log head with the large valves would be the best thing before getting a OZ head. But getting such a head here in the Netherlands is next to impossible and getting one in the USA and shipped here would cost me way to much. But the impossible happened and after looking for quite some time one popped up for sale this week and I immediately bought it.
So after some reading I don't really know what is possible and what not. So here are the things I think I need to do:
Head:
The head needs to be milled 0.030 to get the compression ratio back up, I dont know if this also accounts for the new style headgaskets I read about, some more information about this would be very helpfull. .
I will be doing the 2v conversion and putting bigger valves in. But I got a bit confused after reading some posts about installing bigger valves. Someone said you dont need hardened valve seats if you just want to cruise around, others said it is definitely needed. So I could use some information on this and which valves would be best. For the rockers, I need adjustable rockers when the head is machined.
Carb:
I got a 2150 from a 1970's v8 of some kind laying around, is this a good choice to put on, or do I need a better one for more power or efficiency?
Camshaft:
I don't know anything about camshafts and after reading I still don't know what would be the best one for my build. I read the 264 110H would be a good choice, but i don't know for sure.
Ignition
As for the ignition, I currently use a pertonix, but I see some guys use HEI or DUI distributors. I guess they are better, but is there a big difference between them and a the pertonix unit?
Transmission
I will be installing a 5 speed transmission, but not a Tremec. It is a european ford t9 5 speed. Some guy in the Netherlands did this and posted how to do it on the dutch Mustang forum, but he has vanished a few years ago and nobody knows what happened, the car and owner just dissappeard. It will be interesting figuring out how to make it all fit.
please keep in mind I'm in the Netherlands, this is the land of the ford v6 cologne engines, I'm the only one as far as I know building a 200 like this. So doing this is quite difficult with regards to getting parts and information. Please dont go too hard on me for asking so many things. Links to other good posts would be very appreciated.
By the way, friends of my call me stupid for not putting a v8 in it, but I think this is a damn lot cooler.
thank you for taking the time to read all this.
Henk
Head: c9de 6090 m
Head:
Carb:
Camshaft:
Ignition
Transmission
Henk
