Yeah I’ve checked for that and still the same thing. Could it be the ecu itself?Thats the throttle swinging to check its position. Sounds like the ECU has a problem. Check the plugs on the ecu for water ingestion or earthing problems.
Certainly possible, but less likely than a sensors. Try to do a fault analysis from the OBD port. Most workshops can do this, or you could buy one, get a mobile mechanic to come to you.Yeah I’ve checked for that and still the same thing. Could it be the ecu itself?
