Dragonlich1961
I'm looking to convert my 61 ranchero (sunshine) to efi. Current set up is a 68 block, 78 head, comp 260h cam, 1.5 rockers. 9.2-9.5 comp. Wsa111 tuned duraspark 2 with an msd6al, vintage air ac, custom 2.5 exhaust with dual outlet header. Backed by a t5 and 3.73. Currently running a 32/36 Weber carb through an adapter. I'm having constant pinging issues at part throttle accel and WOT. I've been playing with the jetting on this carb and I've had to jet it up a decent amount to make it this far. Stock jets has it at 16 afr at wide open before changes. I fight with it to stay running when coming to a stop when its cold. Id like to get better mpg and durability out of it. I know it has more on the table but I can't drive it wot with out it pinging.
Current thoughts are to pull my head and mill for a holley 2 barrel pattern, Then run a holley 2300 sniper. I would like to have timing control and was hoping to avoid purchasing the complete system from holley. Everything is neatly tucked away curently and would involve major wiring surgery to free the msd from the car. ( its tucked above the passenger kick panel beside the vintage air gen4 magnum box). Eventual plans would be to build a turbo efi engine for this car later( big bell 200) aluminium head and maybe multiport efi. So im looking to others who have done this in hopes that you can shed some light on this. I will have to either run an external fuel pump or make an internal setup. No efi tank or sending unit is available for the ranchero/station wagon tank as its upside down from the falcon/ mustang.
