200ci DC Head Gasket
This applies only to 200ci
dydaktix
Active member
Getting a 65 200 put in my 62 comet. Mechanic bought a gasket set from DC gaskets, and pulled the head. Anyone use them before? Will the head need to be milled down?
Yea ! - another MEL style Comet...
if head hasn't been removed from factory, the original gasket will be 'steel-shim' and much thinner than modern 'composite' gasket.
if engine internals are viable, with head removed it's a good time to have it freshened with a 'valve job' which typically would include milling head for flatness and original compression ratio retention. (mill - @ .020 - .070")
Depending on your goals and resources, a simple valve grind and milling or full disassemble-back cut vlaves - check/knurl guides and any performance mods can be done.
Hi, don't assume the new 200 has all original parts. Most everything could have been replaced over the years.There is a Ford Falcon Performance Handbook, and a tech section here to help you sort it all out.I got the book from vintageinlines but now I hear they are hard to find. Good luck
Trying to find a copy myself.
I checked Vintage inclines but no luck.
The Ford Falcon site showed it on their site, but it didn’t say it was in stock either. Will have to give them a call.
Not sure why the publisher doesn’t print more if so many are looking for a copy?
