Howdy I've been reading for days here and am amazed at the collectinve knowledge.
I've got an 87 F 150 (Factory EFI) that I will be building a donor engine up for which is also an '87. I know I have the areodynamics of a brick but I am after better fuel economy and I was considering turbo charging. Any one have a daily driver turbo'd? What kind of mileage pre turbo vs post turbo did you see? My best tank so far was 12.8 mpg so it isn't going to take much to improve it, the current engine is tired.
I'm not expecting to run in the 14's while getting 35 mpg but I think I *should* be able to get 15-18 consistantly. One big down fall right now is the 4 sp trans with the huge jump between 3-4. I'm watching the local U wrench it yard for a 5 spd. I know I won't recoupe the money invested in new parts unless i drive the truck 200,000 miles after the mods but I'm rebuilding the engine regardless, I would like to make it as efficient as possible.
Also, what kind of levels will the stock EFI support? 200 horse? 5-7 psi? After all the reading I have done I haven't seen anyone build the stock EFI system. Is there a reason that the stock system wouldn't support very mild levels of boost?
Thanks,
Neal
Thanks,
Neal
