Yes, they will do dyno testing with all the torque and RPM curves.The Bourke engine that you rebuilt and sent to another group for testing, will they do dynamometer testing and record the torque versus rpm?
I would be very interested in the results.
Interesting analysis on the use of an external supercharger. The double acting engine that I'm considering would actually have a short piston, and use one set of Schnuerle ports to feed both sides of the double acting piston. This was done to reduce overall cylinder length/height.
"The only difference is the supercharger is doing it externally with much higher parasitic losses." - Why does pumping air externally inherently have a higher parasitic loss? I genuinely don't know the answer and am curious. I know a lot of 2 stroke engines VE is only about 55% on average.
