MercuryMarc
Just got back from a 500 mile road trip to Reno over a 7,000 foot mountain pass with my Comet. In San Francisco temps are 180-195 on the freeway, and 180-205 in stop and go traffic. Running 12 degrees advance had some pinging on the uphill route so I filled up with 91 octane (was using regular 87) and the knocking resolved. The car ran 190-210 most of the way with a slight grade, increasing elevation, speed 60-70, and outside temps 80 degrees. But near the summit (steeper grade at 70 mph) the temps went to 225 degrees for a few minutes. The rest of the time the car never got over 215 degrees. Cruised in Reno-Sparks for an hour in 1 mph parade with fan keeping the car 190-215 degrees cycling on and off the fan.
I am running:
2 year old 3 row Mustang replacement rad
(smaller inlet/outlet hose openings than the 250's hoses)
Electric Pusher Fan - Derale 14 inch Tornado
Temp switch T'd into T-stat housing, Adjusted to start at 215 degees
180 degree T-stat
*Edit added -13 lb radiator cap w/recovery tank-end Edit*
Tranny Cooler
My question is...
Is 225 degrees too hot on the toughest part of the journey?
Thanks!
(PS- biggest mechanical breakdown of the trip - lost a hubcap 50 miles from home on the way back!!!)
I am running:
180 degree T-stat
Tranny Cooler
My question is...
Thanks!
