Hi,
I need help with degreeing my new Isky cam. LSA of the cam should be 108.
I put the cam straight in with the double roller timing chain, and the cam was 8 degrees off at LSA 100. Now I put the timing chain in the -8° retarded slot and the cam is now at 108.5 LSA.
I just wanted to make sure that I used the right technique/steps to degree the cam....
I attached pictures of my setup and my degree wheel.
1. I established true top dead center for piston #1 with a dial gauge. After that I arranged the degree wheel and pointer that TDC was set.
2. I have a solid lifter and dial gauge on intake lobe of cylinder #1
3. I rotate the crankshaft clockwise, until the gauge reads 0.050" before maximum lift and write down what the degree wheel shows: 64° after TDC, where my index finger on the picture is
4. I rotate the crankshaft further clockwise until 0.050" after maximum lift and also write the number down: 153° after TDC, where my thumb on the picture is
5. I summarize both numbers and divide them by two: (64+153):2 = 108.5
This is my current LSA for the cam
Is this the corret way (or one of the correct ways)?
I am not sure because it is hard for me to believe that Isky ground the cam 8 degrees off?
