I have a 1996 F250 which a previous owner removed a 5.8 V8 and put in a 300 six.
It starts but does not run right. What do I need as far as sensors or wiring / computer do I need to make her run right?
For a maf motor you will need all of the sensors, if are not sure you can get an older speed density ecm which will work good with minimal sensors, 87 to 91 would be the best option
My 87 f350 with the full emission delete still rocks normal fueling and has ignition advance without the quarterhorse installed but dies have the check light
