tjnavyblue
Could everyone with a running turbo blow-through carb application take a moment and list:
1.Size (cfm) and brand of carb
2.Modifications done to carb (drilled metering block, etc.)
3.The engine setup this carb is on
4.Size of jets used
5.Altitude you typically drive at
6.Anything else you think would be good to know if someone were to duplicate your carb setup.
Many of you have discussed your setup in other threads, but I thought it'd be nice to have a condensed thread that documented blow-through carb setups that are currently running.
4.Size of jets used
