F100 Vintage Air
chiefdave
Has anyone installed the Gen 4 Vintage Air? I need to know what 2 grove crank pulley you used. Application is a '62 F100 with 223. Thanks, Dave
While I haven't added air myself, yet. I can add one or two pieces of information that might help. The 262 had a two pulley damper. Where you'd find one I don't know. The Y-block uses the same crankshaft seal so there might be some commonality there. I've also heard a pulley from a 289/302 could be added but I don't know any more details. Hope that will at least give you some ideas to start looking. Best of luck.
Lou Manglass
I found a 2-groove bolt-on pulley on EBay for my 223. It bolts onto the stock pulley and one of the 2 grooves surrounds the damper and the other surrounds the stock pulley, so you have 2 larger pulleys in the same space. It is an original ford part, not sure what the intended application was.
Maybe you can find one too!
chiefdave, if you check out my profile page you'll find some helpful information for your project. If I can answer any more questions let me know.
