charliecurrie
Like to get your opinions on Ford stock ds II vs GM 4 pin control modules. Thanks
chad":aawjj8jq said:1st, Full Disclosure:
the entire 'electric' subsystems (most) are my least knowledgable in the auto.
The recommended 'blue strain relief' module is suggested to be mounted ona good heat sink (disipitation) with dialectical grease. I am not sure of the correct coil (TFI?). But are both oe. Many say it surpasses the MSD and I'd agree. Esp 4 "da mo'nee". I just installed it & the DSII dizzy which seems very good, no long term report yet, "still wrkin on it", but looks sooo much better for oe/era correct (esp w/o the huge HEI dizzy). Rich (here) can talk to you abt the mopwr 'orange' box, similar.
I like the "GM 4 pin" better (but didn't get it free). It too is recommended for a hunka alu mounting/grease but is alot smaller. It has oe looks, it is easy to tuck up somewhere to hide if needed, can throw a spare in the glovie, & is more available too. Not sure the coil here either but everything is on GoFastForLess dot com. (Schematics & great write up on operation/ele theory).
So nxt time I would go w/hybrid HEI 4pin & DSII dizzy (& my RSB carb). There's a 4 pin waithing for when (if) the ford box goes...
You are living in the past. Get your wallet out & upgrade to newer technology.charliecurrie":fb55hdac said:Thanks everyone for your input. It appears that both modules work well if they're of good quality and mounted properly.
I'll stick with my Ford module for now and maybe throw a 4 pin in the glove box for, just in case.
Cheers, Charlie
aka @thegreatwhitewagon on Instagram.
wsa111":i8li52q4 said:You are living in the past. Get your wallet out & upgrade to newer technology.charliecurrie":i8li52q4 said:Thanks everyone for your input. It appears that both modules work well if they're of good quality and mounted properly.
Cheers, Charlie
I will say it again if you purchase a stock or reman. DS11 you are leaving drivability, performance & fuel economy on the table.
we're of 1 mind (& wallet). Seek the same top notch performance & 'visuals'.charliecurrie":2lgrhldu said:...It appears that both modules work well if they're of good quality and mounted properly.
Cheers, Charlie
chad":oog44e8k said:we're of 1 mind (& wallet). Seek the same top notch performance & 'visuals'.charliecurrie":oog44e8k said:...It appears that both modules work well if they're of good quality and mounted properly.
Cheers, Charlie
I'm bettin my ford box never fails but will B, as U, prepared for rd side or garage quick return.
Also, U have more knowledge than me on the "ignition electrics". Did U read the accompanying literature
on (I think his name is Mike, it's been a decade since I visited) the site? Taught me alot (all I know anyway, aint much).
Did U find it helpful or backward or...what? May B didn't read~
