Hey guys, I have a 65 Mustang with a swapped rear end (8in with 4 Lug from a Maverick). I got the appropriate backspacing (4.25 inches) after swapping the rear end. I did a little bit of shaving on the fenders (both sides are evenly proportional). I put on 255/60/15 tires with a wheel size of 15x8. Someone on the forum helped me out with the sizes and what could and could not fit and I also measured the back just in case. After shaving and measuring, only my left rear tire is rubbing/scraping on the fender but I can’t find out where exactly. The tires are not touching the leaf springs nor anything on the most inner wall of the fender. I had two people sit above the tire and two people sit inside the car and nothing seemed to be touching the tire on either side. Has anyone had this issue? I’m thinking of going down to 235/60/15 to be on the safe side but the thickness of the 255s are perfect.
Quick summary: My left tire is rubbing/scraping somewhere on the fender and I can’t find where. My right tire is completely fine.
