So, i've got my block back from the machineshop, bored ,030 over, linehoned mains,. 030. 020 undercut crank, balanced crank, dampener and lightnend flywheel, cut down for Mercedes presureplate. Weightadjusted rods with Arp bolts, Silv-O-Lite 3327 hypereutectic flat tops .020 out the hole. With The standard Felpro headgasket, that would bring a. 030 squish. Aiming for a 10-10.5:1 comp ratio. I'm looking at this cam, would have wanted it with a 110 LCA.
Ford 6 Cylinder
Part # 07-027
144, 170, 200, 250
Grind #
H-280-8-BHL
Advertised
Numbers
Numbers
@ .050
Intake Duration
280
231
Exhaust Duration
280
231
Lobe Center
108
108
Center line Timing Events
106 INT
110 EXH
Intake Valve Opens/ Closes
9.5 @.050
41.5 @ .050
Exhaust Valve Opens/ Closes
45.5 @ .050
5.5 @ .050
Valve Lift
Based on 1.6 Rocker Ratio
.512 INT
.512 EXH
Valve Lash (Hot)
½ to 1
Full Turn
½ to 1
Full Turn
Set Springs up at 120-130 lbs Seat Pressure
CSC recommends degreeing your
Camshaft in on the #1 Intake using the Lobe Center line Method.
I'm running a triple Weber IDF44 setup with 36mm venturis and a: 12" intakerunner length from valveface to airhorn mouth. Building a zero loss exhaust system as by David Vizard, for my longtube Hooker header.
What do you more experienced builders think of my overall plan and cam choise?
