Some parts I have been specing out for a Ford 200 build with the exception of the valve springs and cam choice these parts, with proper conecting Rod prep, and a good piston choice should be quite capable of 6000 to 6500 RPM.
Cylinder Head Parts
Ford Log Head 3/4 Exhust Port Divider @ Vintage Inlines for $25.00
Here it is, the controversial port divider! The theory is that if the siamesed #3 & 4 exhaust ports are separated, the resulting "balance" will help performance. If used, this piece must be installed per the manufacturers instructions! Do not do it any other way. Tack weld it in with a nickle...
www.vintageinlines.com
5/16 PC Type Valve Stem Seals Set of 12 @ Clay Smith for $22.95
Clay Smith Cams, home of Mr. Horsepower engineers world class camshafts and custom cams. If you need extra horsepower, performance and the muscle car sound, check out our line of cams.
www.claysmithcams.com
Set of 5/16 Steel Valve Spring Retainers @ Clay Smith for $50.00
5/16 7 Degree Valve Keepers set @ Clay Smith for $10.50
Clay Smith recommends for some of their Ford Six cams that the closed valve spring seat pressure be set at 120 to 130 pounds. The Valve Spring I have been looking for is a 302 V8 type Spring with a Dampner they are the old Clastic Inlines part # CSC-200-STY (by Clay Smith Cams) so far I haven't been able to find them listed on the Vintage Inlines site. They have a little more seat pressure at 100 pounds with the Dampner to cut down on the harmonics. Clay Smith might still know of these and if they carry them or one that is a better match for their current cams.
For example for the Clay Smith cam listed below that has .468 gross lift using the 1.5 ratio rocker arms the Valve Springs will need to have a minimum of .528 clearance (more is better) before going into coil bind / or stacked solid and there should also be enough clearance between the bottom of the valve spring retainers and the top of the valve stem seals so they don't touch at the full valve lift of .468 (again more is better) this is when using the 1.5 ratio rocker arms.
For Larger Diameter Intake and Exhaust Valves they are available @ Vintage Inlines and "SI Valves"
http://sivalves.com/pdfs/2016-SI-Catalog.pdf
They make several sizes of larger Ford 200 / 250 Six intake valves and one larger Exhaust Valve, Vintage Inlines may also have these though I haven't been able to access their listings yet.
The Intake Valves are the Port Flow Type
1.760 HD SEV-3007-S
1.800 HD SEV-3008
1.840 HD SEV-3008-S
The Exhaust Valve is a Port Flow Type
1.500 HD SEV-2530-S
New Ball and Cup Push Rods for use with the stock 1.5 ratio adjustable rocker arms or the below 1.6 ratio Adjustable Rocker Arms you might need a custom lenght.
These non-oiling chrome moly push rods fit 170/200ci motors with adjustable rocker assemblies, including our adjustable roller tipped rocker assemblies.
The stock 1.5 Ratio Rocker Arm set is available @ Vintage Inlines as a rebuilt set for $275.00
*** Out of stock indefinitely. There are no cores for us to rebuild. If you have an adjustable core and would like to have it rebuilt, email us at info@vintageinines.com. Rebuilt adjustable rocker arm assembly with 1.5 stock rocker ratio. Fully assembled and ready to bolt on. Fits all...
1.6 Ratio Adustabe Rocker Arm Set available @ Vintage Inlines for $350.00 gives a little more valve lift over 1.5 ratio set above.
*** Out of stock indefinitely. There are no cores for us to rebuild. New 1.6 ratio, adjustable rocker arm assembly, fully assembled and ready to bolt on. Requires adjustable style ball and cup push rods (sold separately) if you are replacing a stock non-adjustable rocker assembly. High ratio...
Short Block Parts
Double Roller Billet Timing Chain and Gear Set Multi Adjustable is top of the line and the best quality @ Vintage Inlines for $129.00
These dual roller chain sets feature billet gears with hardened teeth. The crank gear has nine key ways for adjusting cam timing in 2, 4, and 6 degree increments (advance or retard). They offer greater strength and reduced chain stretch over stock chains to maintain accurate cam timing, and...
Camshafts & lifters by Clay Smith available @ Clay Smith or @ Vinage Inlines for a reasonable price. There many different grinds that can easily go to 5500 to 6000 RPM in both Hydraulic or Solid lifter types and you might also look at some other choices such as a custom grind from Shindeler Racing Cams.
http://schneidercams.com
Example of one Clay Smith Solid Lifter Cam @ Clay Smith it may or maynot be the right grind for your application.
Ford 144 & 170 Stock Solid Valve Lifters @ Rock Auto for about $5.01 Each X 12
Camshaft New Thrust Plate (Optional) If you should need one it's available @ Vintage Inlines for $5.00. if your used thrust plate shows any scoring or other type of damage then it should be replaced.
This camshaft thrust plate fits small sixes from 144 to 250 cubic inches.
Camshaft Spacer Ring (Optional) if you need to replace one @ Vintage Inlines now has them new for $14.00. These have been very hard to find until now so if you happen loose your original, or break it, they are also often forgoten and left on the old camshaft during a cam swap.
This is the cam spacer between the cam thrust plate and the timing gear. Exact replacement for lost or damaged original parts. Free shipping on this part.
ARP Rod Bolts (Optional) these Conecting Rod bolts are for some extra insurance. They are not be absolutely nessisary for many street performance builds but if your going to be rebuilding the rods anyway then its a good idea to install them before you have the rods resized.
Rod Bolt Kit for all 170/200/250ci motors. The 24 piece set includes SBF rod bolts and nuts. While this kit requires some machine work, it is very easy to do and can be done by any machine shop for a few bucks. ARPĀ® studs and bolts are approximately ten times stronger than OEM fasteners. A...
ARP Head Studs (Optional) some people prefer to use the Head Studes over the stock or ARP Head Bolts.
Head Stud Kit for all 170/200/250ci motors. The 42 piece set includes studs, washers and nuts. ARPĀ® Bolts and Studs are approximately ten times stronger than OEM fasteners. For most performance applications, studs are recommended over bolts. Studs make it much easier to assembly an engine...
