End of Saturday update.
As a reminder, 9am next Saturday this thing needs to be doing laps in beautiful Buttonwillow, CA. Any and all options are filtered against a need to have this thing on a trailer by Thursday afternoon to pass tech on Friday to do laps on Saturday and Sunday.
So,
head gasket is just straight blown. GM magic tablets seemed to seal it for a bit, but then it got back to bubbling a bit out the side once things got really hot. Also,
definitely have combustion gasses pressurizing and heating the water. While breaking in the cam we could only run it about 5min at a time before it'd hit 210-220. The radiator would start puking at like 210, which tells me it's pressurizing like crazy to overcome the 20psi cap.
Next thing we're doing is to just hit it with Blue Devil headgasket in a bottle stuff. If that seals we'll just send it. It's suboptimal, but things just get weirder if we go further down the diagnostic and parts-swapping rabbit hole...
If the Blue Devil doesn't seal, then I've got a previous "race" head that's milled for compression I could swap in. It ended its last race with a blown HG or maybe a cracked block or something. It was running stupidly hot if we got above like 3500rpm, then the #1 rod went though the side of the block.
Tricky part is ^^^ that head was milled for compression with
stock pistons. With my current 255 pistons it'd give like 10.4-10.5:1 static CR, but with the 274/274 108 LSA cam the dynamic CR should be around 9-9.1. Pretty aggressive, but I do have access to race gas (and octane booster). Doing just a head is attractive because we've got that down to about a 2 hour job.
Next
next option is to swap to a backup craigslist-sourced bottom end that "was running". I can drop the shaved head on that and have decent compression, etc. It's just a lot of unknowns (literally) stacked atop each other. That's also an ~8 hour job.
I still have no obvious root cause, but the following are possibilities:
- Head is not level. I think no because: It was milled, straight edge shows no warp, resurface-on-glass action showed no obvious warping/high spots.
- Block deck is not level. Didn't have this one decked, so might be the case. I kinda think no because: I checked it with my straight edge and wasn't obviously off, but side-to-side is tough to gauge. Wouldn't trust it 100%
- Head studs are stretching/yielding/otherwise not clamping. No indication other than poor HG sealing. If true this would explain like everything. I do have a different used set I could swap in.
- FelPro made a bad batch or change to gaskets. Normally I'd be reluctant to even consider this, but I'm on a streak of like 4-5 failed FP gaskets at this point. Again, if true this explains everything. They're just way more available than Mahle or Victor Reinz. Anyone else recently have FP HG issues?
That's all I've got for now.
