mad_science
Fired my "race" 250 for the first time last night, everything seems good, but noticed a pretty big external coolant leak all down the driver's side of the head/block interface.
Backed off all the bolts and re-torqued, but still leaked.
After pulling the head, can see evidence that all of the coolant passthroughs were leaking between the head and gasket.
Anyone have anything like this before?
I've done ~10 HGs on 250s at this point (courtesy of overheating at the track) and have never seen this before.
Background info:
Don't have time before the race (Oct 1) to send any parts for machining, so at this point our next step is to clean up both surfaces as much as possible and just re-do it. Will probably do a very slight edge break on the edge of the head and block, just to make sure there isn't a knick or high spot that was screwing things up.
If that doesn't work, will probably default to one of the "head gasket in a can" desperation options. If that doesn't work, I've got an $80 Craigslist motor in the back of the garage that might get called in a-la Rudy.
Background info:
- ARP head studs, torqued to 80+ lbs in the proper sequence
- FelPro gasket, installed without any sealant or goop or anything
- Head was level-decked at machine shop, not milled down
- Block was not decked, but checks out as level on machinist straight edge
- Running 255 pistons, so static CR in the mid-9s
