The charts below were calculated using Virtual Engine 2000's Cam Utility Program. The charts list both Static and Dynamic C/R's for a 200ci engine with a zero deck height, using varied chamber sizes and valve timing (intake close). Calculations were computed using a Felpro head gasket which has a .050 compressed thickness and a 3.81 gasket bore. The columns to the left use dished pistons (6.5cc), the columns to the right use flat top pistons.
[ATTACH type="full" width="100%"...
