JMB wrote:Thanks for the reply to all.
Can these blocks be sleeved?
If they could, will the sleeve make it stronger?
Is it worth the cost to have it sleeved?
Are these blocks available NEW? Thanks again.
JMB wrote:Mustang_Geezer,
Thanks for the reply.
Are the bolt paterns where the bellhousing meets the block the same on the 66 as on the 78 block? Thanks.
Yes they are the same.
The only differance in the blocks (to my casual inspection) is the 66 block has the provisions for the draft tube and the 78 block doesnt
JMB wrote:Mustang_Geezer,Yes they are the same.
My question is :
I am planning to put a T5 trans from Modern Driveline.
The reason I asked if the bolt paterns on the blocks are the same is because (Modern Driveline) told me that the 66 200 inline 6 is a stand alone year and that they have a different bellhousing than any other years.
Is this true?
Will the bellhousing from a 67 - 78 bolt up to my 66 block? Thanks again.
My question is :
Is this true?
rbohm wrote:8) the 66 and earlier blocks use a smaller bell housing bolt pattern in so far as the upper two bolts are set lower. look at the back of your 78 block and you will see two bolt patterns. the 66 block does not have the upper two bolts.
Frankenstang wrote:rbohm wrote:8) the 66 and earlier blocks use a smaller bell housing bolt pattern in so far as the upper two bolts are set lower. look at the back of your 78 block and you will see two bolt patterns. the 66 block does not have the upper two bolts.
Don't you mean the '65 and earlier are non-dual pattern...both my '66 blocks are dual pattern.
JMB wrote:I heard from Bruce at Modern Driveline that he is making a bellhousing made out of steel for the 66 and newer 200 inline 6 blocks to bolt up to the T5 without the need of an adapter and will have the ability to use a Clutch Cable or a Hydrolic Clutch System. Hope he will have it soon.
...will be curious to see that come out. I keep hoping Mike/AZCoupe or someone will decide to recast the stock aluminum 'holy grail' '81 bh that's the right depth (no adapter) and cable ready for the 200...unfortunately it's extremely hard to come by second hand.Mustang_Geezer wrote:The 66 block will have forged rods the 78 block will not.
JMB wrote:Frankenstang,
I think you are right. Bruce told me that it will be a shatter proof bh's and that it will be 12lbs heavier than the aluminum bell.
What years and in what cars did that (stock aluminum 'holy grail' bellhousing with the Clutch Cable provision) come in?
Did they also come in the cars with 250 motors or just the 200's. Thanks.
I got 350 heads on a 305 engine. I get 10 miles to the gallon, I ain't got no good intentions.
- Mike Cooley, aka the Stroker Ace.
Return to 144-250 "Small Block" Six Performance
Users browsing this forum: bmbm40, '68falconohio and 0 guests
