All Small Six Are These Anything? Never Saw a Carb Spacer Like This Before
TrickSix
Looks like it has the same manifold bolt spacing as the regular large log spacer, and the same 1-3/4" bore. But the carb mounting studs are 3" apart instead of the usual 2-5/8". Are there larger bored, maybe 2" or so, one barrel carburetors with that 3" bolt pattern?
No, I don't need it. I was just curious, and thought someone else might find it interesting. I think I saw the EGR flange version of it in a box of parts I got with a couple heads. I never paid any attention to it once I saw the EGR flange though, and didn't realize the carb studs were wider.
The carb studs on the 78 large log head carb adapter that I have are about 2-15/16" apart center to center.
3" on center studs would work with a China elec choke Carter YFA carb that I used to run.
